Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Power (sleep/wake) button not working after screen replacement?
Hello, this is the second time I have replaced the screen on my iPhone 6, however this time when I put the phone back together the sleep/wake button doesn't work, has anyone come across this before or what I may have done wrong?
Thank you
Add a comment
Chosen Solution
Does your flash work? I ask because the power button and flash are on the same flex.
Normally, changing a screen should not have any interaction with the power button connector or flex and none of the circuitry is anywhere accessible for just a normal screen replacement.
Did you remove the logic board or anything other that what is saidin this guide?
Think back about what you did and try to remember if your screwdriver slipped or anything else that may have damaged the flex or button.
EDIT:
You may want to look at the power button from inside the phone with a magnifying glass or jeweler's loupe to see if the mechanism is indeed touching the actual actuator on the flex. If everything looks okay try to disconnect the battery one last time. A hard reset would be nice but without a working power button that is difficult. You could try to reset your device via iTunes.
Otherwsie, I would try a new flex and follow these instructions.
iPhone 6 Power Button Cable Image
Product
$16.99
iPhone 6 Screen Image
Guide
iPhone 6 Screen Replacement
Difficulty:
Moderate
20 minutes - 1 hour
iPhone 6 Power Button Cable Assembly Image
Guide
iPhone 6 Power Button Cable Assembly Replacement
Difficulty:
Difficult
1 - 2 hours
Score 1
1 Comment:
I can confirm the flash does work, and I cannot recall slipping with the screw driver or anything, I followed the instructions on the guide to the T and thought it went pretty well, that's why I have no idea why it's stopped working
by
Add a comment
I had this issue with an Iphone 7 Plus. I tried disconnecting and reconnecting the home button flex cable located directly above the battery beneath a metal shield, and it now works.
Add a comment
Add your answer
David Walters will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 14,317
